query input validation
adamohern
Member, OS Professional Posts: 216 PRO
Is there a way to reject a query selection based on arbitrary criteria? For example, what if I wanted to accept a face as an input, but I wanted to reject any face that lacks at least one linear edge? What if I wanted to only accept circular faces, blue faces, or faces whose Normal points 37 degrees North?
Unfortunately, no, these filters can't be arbitrary, and none of the specific options you listed are supported. You've probably seen the documentation for query parameter annotations which tells you you can filter by EntityType, BodyType, GeometryType, ConstructionObject, SketchObject, and EdgeTopology.
Probably the way to handle such requirements is allow selection of a broader set of things, and call reportFeatureInfo() to pop up a message letting the user know that their face didn't have a linear edge or whatnot.
Right now, reportFeatureInfo() only allows an enum full of errors written for Onshape features (this was done for security and translatability), but you'll be able to pass in any string you want in the very near future. println() is an okay stand-in for the short interum.
Great, thanks!0
@kevin_o_toole_1 Unless you guys are completely refactoring the library with a new error.fs, it could be useful to add an ErrorStringEnum.FEATURESCRIPT_ERROR with a generic message that directs the user to the Notices flyout.
We have an improvement coming soon to allow custom error messages.traveler_hauptman said:@kevin_o_toole_1 Unless you guys are completely refactoring the library with a new error.fs, it could be useful to add an ErrorStringEnum.FEATURESCRIPT_ERROR with a generic message that directs the user to the Notices flyout.0 -
We released the update a couple hours ago. Check out the new versions of regenError in error.fs. This will only work in new documents; your old feature studios will see the old version of std.1
