rounding extruded edges on sides, not faces
adamohern
PRO
I'm extruding rectangles, and by trial and error I found that the following code does exactly what I want:
This works for rectangular extrudes, because it just-so-happens that Onshape puts the extruded edges (the ones running normal to the sketch plane) first in the qNthElement() list. All I have to do is gather up the first four, and I know I've got all of the vertical edges.
Two questions:
1) Is there a cleaner way to do this in my situation?
2) Is there a generalized way to access all of the non-end-cap edges of an extrude regardless of profile shape?
var filletCandidates = qCreatedBy(id + ("extrude" ~ i), EntityType.EDGE);
var filletEdges = qUnion([
qNthElement(filletCandidates, 0),
qNthElement(filletCandidates, 1),
qNthElement(filletCandidates, 2),
qNthElement(filletCandidates, 3)
opFillet(context, id + ("fillet1"), {
"entities" : filletEdges,
"radius" : definition.edgeRadius
});This works for rectangular extrudes, because it just-so-happens that Onshape puts the extruded edges (the ones running normal to the sketch plane) first in the qNthElement() list. All I have to do is gather up the first four, and I know I've got all of the vertical edges.
Two questions:
Have you seen qCapEntity()? It takes in an id (e.g.
id + ("extrude" ~ i)) and a boolean for whether to return the start or end cap entities (I don't see a way to get both at once). Using a qSubtraction() between yourfilletCandidatesand the results of the qCapEntity()s should give you just the non-cap edges.1 -
Sounds promising! Will give this a shot. Many thanks!0
Beautiful, Jacob. This worked for me. Thanks again.
var filletCandidates = qCreatedBy(id + ("extrude" ~ i), EntityType.EDGE); var capEntities = qUnion([ qCapEntity(id + ("extrude" ~ i), true), qCapEntity(id + ("extrude" ~ i), false) ]); var filletEdges = qSubtraction(filletCandidates, capEntities); opFillet(context, id + ("fillet1"), { "entities" : filletEdges, "radius" : definition.edgeRadius });0
