opSplit > opDeleteBodies called repeatedly on the same body from a loop
adamohern
Member, OS Professional Posts: 216 PRO
I have a feature that splits a body with a plane using opSplit, then deletes half using opDeleteBodies. Works fine in isolation.
My intended use, however, is within a loop. I select multiple planes, a single body, and the feature loops through each plane lopping off the appropriate part of the body.
The problem is that my split/delete function doesn't work in this context. I assume it has something to do with internal ID's changing during the split operation or something. Anyway, it works fine when run by itself, but not when trying to do it repeatedly to a single body.
Any hints?
Any hints?
I think we'll need a bit more information to help. What is the error message you're seeing? Can you paste the loop code?
The usual issue with this type of thing is that ids of operations have to be unique (and hierarchical), so you need to do something like:for (var i in [0, 1, 2])
opSplit(context, id + i + "split", { ... });
opDeleteBodies(context, id + i + "delete", { ... });
}Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
