Insight into queries?
traveler_hauptman
Member, OS Professional, Mentor, Developers Posts: 423 PRO
I feel like I'm not getting the query system. I get the basics. But then I see something like this:
export function evLength(context is Context, arg is map) returns ValueWithUnits
<snip>
var edges = qEntityFilter(arg.entities, EntityType.EDGE);
var ownedEdges = qOwnedByBody(arg.entities, EntityType.EDGE);
return @evLength(context, { "edges" : qUnion([edges, ownedEdges]) }) * meter;
and I get confused.
Why did qEntityFilter not capture the edges owned by entities, making the qUnion necessary?
Does qEntityFilter only work on things that are not owned?
In this case, arg.entities queries for a mixture of edges and bodies. qEntityFilter just extracts the edges that are directly queried for. qOwnedByBody just looks at the bodies -- and then gets their owned edges. Another way to thing about it is that the result of a qEntityFilter query is always a subset of the subquery passed in -- that's what it means to filter -- so it would be weird if you pass in one body into qEntityFilter and out comes a whole bunch of edges.
I'm not sure if that makes it more or less clear...Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0 -
That clears it up. It did not occur to me that bodies would be the query passed to qOwnedByBody. I thought it was taking a list of edges and returning edges that were owned by a body.
Ah, ok. Actually, *every* edge (and face and vertex) is owned by some body. You can get that body using qOwnerBody.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
