Debugging sweeps...
biscuitlad
biscuitlad Member Posts: 8 ✭
edited April 2016 in Community Support
Hi folks
So, I want to design a new frame for a pair of sunglasses I have.  The prescription lens are very expensive, the old frames broke.  So, I have the lens, I have a micrometer, should be simple, right?  ;-)
I import two photos of the lens. One to give me the face profile of the lens shape, the other to give me the curvature of the lens (from above - these are wrap-arounds).  I scale the photos, sketch up the profiles and create a curved vertical surface to match the wrap around curvature of the lens.
I then extrude a surface from the face profile onto this curved surface using 'up to next' (or face, both work).  Great, I think, I have the front profile and the top curvature, now all I need to do is to create a sketch for the frame itself perpendicular to the face (i.e. on the Right plane) and use the intersection of my previous two surfaces as my sweep line.
But, no matter what I do, I can't get this to sweep.  I have constrained the sketch so that the top of the V groove that holds the lens in place pierces the path made by the intersection of the two surfaces.  I have checked that the ends of lines / curves in the sketch are coincident so they join correctly.  The profile selects with a click, it all looks good.
But the sweep will not generate.  Please, is there any one out there who can tell me how to fix this?  :-)
The model is public:
https://cad.onshape.com/documents/ede1cbed4ded3dc73ba7ae74
Many thanks.
  • biscuitlad
    Many thanks Pierre for revisiting this post from a year ago! I gave up on this model as onshape at the time was just too buggy to get it to work, but I'll revisit it soon and see if I can use your solution.
