Angled surface diameter
in Drawings
Hello!
One of my parts is made of sheet metal, since we don't exactly have tooling for that what I did was to model the bend as a sketch and extrude it. Works fine, except that one of faces that is bent 105 degrees has a hole on it (made by creating a different sketch and extruding it to remove). This also works well.
Problem: when creating drawings from the parts I can't use the diameter tool to size that hole. When I look at the views I can notice that they are being viewed by a 90 degree angle so it's not really a circle. Is there a way to add a view of that angled part that is perpendicular to the side so the hole can be measured?
Am I doing something wrong? (Aside from shoehorning sheet metal design).
