How do we select rotation center in OS?
afbenevides
Member Posts: 4 EDU
in Drawings
In Catia we can use middle click to position rotation center. Is there the equivalent in OS?
afbenevides
Member Posts: 4 EDU
Ok I found on another comment that hovering over the point you want to use as center of rotation makes it the center of rotation after you right click as you said. Thanks!shashank_aarya said:In Onshape it is right click at any point, and drag to rotate. It will rotate about the selected rotation center
5
Windows
Mouse
3D Rotate: Right-mouse-button-click+drag
Zoom in and out: Scroll up and scroll down, respectively
2D pan: CTRL-right-mouse-button+drag (middle button click+drag)
Touchpad
Zoom in and out: Pinch out and pinch in, respectively
Apple Mac
Mouse
Zoom in and out: Scroll down and scroll up, respectively
Rotate the view in 45 degree increments: Click arrows around the View Cube.
