Calculator
bert_fouriebert_fourie Member Posts: 103 PRO
It would be very nice to have a floating calculator in the Part Studio - or is there a facility i am not aware of? I know a calculation can be done in the entry fields, but sometimes one would like to do a calc outside of the field.
    If you have a 3Dconnexion device, there is a built in calculator (https://www.onshape.com/cad-blog/achieve-more-with-a-3d-mouse).
    Of course, both MacOS and Windows come with built-in calculators
    AND (drumroll) you can type any arithmetic expression into the parameter input field
    AND when you return to the calculated field, you can see the original expression. :)
    Philip Thomas - Onshape
  • bert_fouriebert_fourie Member Posts: 103 PRO
    Thanks for the advice
  • michael3424michael3424 Member Posts: 758 ✭✭✭✭
    Don't forget Smart Calcs in the Onshape App Store - that could be useful for documenting design criteria.
    Yes, I have been considering that - will give it a try. I usually do all my calcs on spreadsheets.
    In terms of the calculator I am old school - having used HP RPN for so long I find myself constantly reaching for my cellphone with the HP 41CV app on it :)
    RPN forever!  Which 41CV app do you use on your cell phone?
    i41CX from AL Software - how about you?
  • stg434stg434 Member Posts: 21 PRO
    HP42S by Thomas Okken
    I just use a generic RPN calculator.  Got a pile of old HP calculators to choose from here and should probably get rid of them while they still work.  They are easier to use than the smartphone versions so long as one is close at hand.
  • tom_scarincetom_scarince Member, Developers Posts: 48 ✭✭✭
    I use Realcalc - I think I had to turn on RPN mode in the settings.
