Problem creating a drawing
stephan_tobiasstephan_tobias Member Posts: 2
I created a simple part... right clicked on the part studio tab, create a drawing... following I clicked 4 view, and ok... no drawing was created, it simply states loading.
    @stephan_tobias, It generally takes near about 2 to 10 seconds time for loading depending upon internet speed. Kindly check your document tab in which you will definitely find your drawing tab for that simple part. kindly refer below video step which will be helpful to you.
    If drawing tab is not created in your document then you can share your document with Onshape support team they will definitely help you.
