Storage Size upon Export
For some reason it seems that my data usage for a part goes up dramatically if I export it (for example, to send to someone who needs a step file).
As a result my storage has filled up really fast. Is there a cache of "converted parts" somewhere I can clear?
Thanks!
Thanks!
-First way to reduce the file size is make a copy of your document, this will purge all your version/history . Remember to also empty the trash, the files there count up in your storage. Lastly as you are already above the limit it probably wont allow you to make a copy privately, so make the file you want to copy public a few seconds while you copy the file.
-Making a document (temporarily) public seems to be the second way to reduce its size if you are over the free plan limits.
