Text is upside down and backwards.
jay_williamsjay_williams Member Posts: 21
I want to put some (sunken) text on a part, but on the underside of the part with the part upside down compared to how it is when viewed during sketching. So, I oriented the part the way I would if I were going to write the text onto it, but when I add the text, the text is upside down and backwards. How do I get the text on the correct side of the part and in the correct orientation?
Thanks,
Jay
    I believe that you'll need to rotate the text 180°
    edited May 2016
    @jay_williams, Apart from transform sketch (faster as compared to below method) as suggested by @Shanshan , you can use one more method.
    For that you have to remove the horizontal constraint from the box that contains the text and simply rotate it to your desired position, Kindly see below video for more detail.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 6,071 image
    Sounds like you are creating the sketch then rotating the part to the view you want? Make sure you choose a sketch face or plane that is in the correct orientation first before creating your text. Select the bottom face to sketch on or create a plane if the bottom face is not planar. Press N to view normal to sketch plane.
  • jay_williamsjay_williams Member Posts: 21
    Thanks for the help, folks!
  • johan_ariffjohan_ariff Member Posts: 1
    Dear guys....
    What about flipped text? Transform can only be use for rotating in this case... Tried searching high and low but to no avail... :neutral:
    My screenshot below... i need to embossed/engrave 'CBMTI'...
    I notice it follows my plane's normal direction.. that too i can't find a way to change the normal of my plane :-( please he
Howdy, Stranger!
