STL export into Vectric Cut3D
david_fisher031
david_fisher031 Member Posts: 24 ✭✭
edited May 2016 in Community Support
On opening an STL model generated by Onshape in Cut3D it appears as it should. When I generate a cutting path it seems to take much longer than something similar I've generated from Openscad and the estimated time to cut is much longer. When I preview the cutting, it generates a wrong result, it is lower on one side than it should be. I have tried the different settings from fine to coarse with the same result.I don't know whether this is an Onshape or a Cut3D problem, my Openscad STL files didn't have this problem. Has anybody else had this problem with STL or Cut3D.
  • david_fisher031
    I think this is a cut3D problem not an Onshape problem. I have reproduced the problem with other STL models from different sources. Here are a couple of screenshots of the problem.
    When it is first opened.
    When the cutting has been done in the preview. The right hand side is the same height as the front of the inner cutout.
  • david_fisher031
    Thanks for the tip, I use a Roland mill 40a at makespace in Cambridge England, and at the moment we are locked down into using Cut3D.
