Can ANSI holes be exported to STL?
Jlabs
Member Posts: 28 ✭✭
I've created a test plate with 1/4in 20 through holes and selected "tapped". When I view the STL file the holes
By specifying a tapped hole, Onshape is calculating the drill size and applying that to the model. If you want the actual thread for 3D printing then you will have to model it yourself using a helix and a sweep.Senior Director, Technical Services, EMEA5
Thank you. That would be a cool feature to implement, would save a lot of time.0
Why specify tapped hole information in modeling, when none of it translates to the drawing. No hidden line representation of the threads. No defined tapping depth. Just a hole. What a waste of time. Now I have to return to the model figure out what I defined and write a note for manufacturing.
