Problems with skArc
sören_svensson
sören_svensson Member Posts: 24 ✭✭
Hi,
I'm creating some corners with skArc but some are ending up inside-out!
I'm using the getArcMidPoint function posted here earlier.
All the small arcs in the picture below should be "outies" and the large center one "innie".
Here's the code for the lower left one (ll and ur are vectors)
start = ll + vector(0 * millimeter, radius);
        end = ll + vector(radius, 0 * millimeter);
        mid = getArcMidpoint(ll + vector(radius, radius), start, end);
        skArc(sketch1, "arc2", {
                "start" : start,
                "mid" : mid,
                "end" : end
and the top right
start = ur + vector(-radius, 0 * millimeter);
        end = ur + vector(0 * millimeter, -radius);
        mid = getArcMidpoint(ur + vector(-radius, -radius), start, end);
        skArc(sketch1, "arc8", {
                "start" : start,
                "mid" : mid,
                "end" : end
Anyone have any idea why and how to control it:
Regards
Soren
  • ilya_baran
    Try switching the start and end arguments to the getArcMidpoint function -- I think that function (Neil wrote it) gets the midpoint assuming the arc is counterclockwise from start to end.
  • sören_svensson
    Thanks, worked perfectly!
    I should have thought about that  :#
