How do you make a composite GD&T control frame?
in General
I know Onshape has the ability to create standard GD&T control frames (though, not to attach it to a dimension, that I know of; that is for another discussion). It can also create multiple single segment control frames, which is nice. However, I cannot figure out how to make a composite control frame (in this case, for the common use of refining the position of patterned holes in relation to each other). Is this not a capability of Onshape? It seems a bit weird that there would be the ability to create multiple single segment frames, but not composite.
If this is not a feature that is currently available, how might I add the necessary composite control frame to my drawing?
