Why importing from other onshape docs convert from mm to inches?
pieri70pieri70 Member Posts: 10 ✭✭
edited June 2016 in Using Onshape
Hello
I'm beginning to use OS
I was attempting to copy a public document and then make some mods.
Until today all went fine.
Then I cancelled by mistake a piece and  tried to copy another one from a public document.
My problem is that when I copy the part studio to clipbord an then paste in My document by import function, the part studio is converted to inches...
In my preferences I set mm/deg/gram under preferences.
If I examine the code of my previous parts I can see:
FeatureScript 370;
import(path : "onshape/std/geometry.fs", version : "370.0");
annotation { "Default Units" : ["degree", "millimeter", "pound"] }
export function main()
    return build();
export function build()
    const context is Context = newContextWithDefaults(millimeter);
The part to import code is:
FeatureScript 370;
    return build();
    const id is Id = newId();
Once I import it the code changes to:
FeatureScript 370;
annotation { "Default Units" : ["degree", "inch", "pound"] }
    return build();
    const context is Context = newContextWithDefaults(inch);
Why?????
Then
My document was 80MB, I eliminate almost everything unnecessary and it is as big as it was.
As I eliminate things the dimension rises...
Why???
Thanks
Pietro
  • pieri70pieri70 Member Posts: 10 ✭✭
    Ok, got it
    it was the document units...
    But I'm almost sure I didn't change them...
  • ethanethan Member, Onshape Employees Posts: 24 image
    Document units are default inches. Each new document must be changed. Or you can change the default units in your account settings.
    edited July 2016
    Yes I realized this..
    But my document was a private copy of a document found in Onshape, and it was originally in millimeters...
    And I was making mods in millimeters for a period..
    Then at some point OS decided, by itself,  that some pieces imported were in inches..
    And all new Part Studios had to be in inches..
    For the dimension problem..
    I copied/pasted all pieces in a new document and magically the new document went from 80MB to 12MB.
