How Do You Widen Text in a Sketch?
I've been pouring over these forums, and I can't quite find my answer. I need to widen the text of a part in one direction (horizontally). Is there a one-direction scale feature? Why doesn't Onshape have a scale feature in its sketches? I'm a bit of a CAD newbie, so any help is appreciated.
This is most awaited feature by many of Onshape users. At this point of time there is no specific scale option available. But there is a workaround for this. First position the text by giving horizontal and vertical dimensions. After that you can simply drag the corners of the text box. It will get resized uniformly. See the below GIF.
1 -
Thank you for the reply! It wasn't exactly what I needed (should have been more specific), but that is the best answer I've seen. I wanted wider text. Sort of like a customized bold, but obviously, that isn't happening. I really appreciate the reply, though! I can't wait for Onshape to listen and deliver more text and scaling options for parts in general.0
@brittany_mcgarr I know this is not exactly what you were looking for, but I have implemented a new text feature for public beta.
Among other options, it features the ability to add horizontal spacing to text ( IE, Height and spaced width are independently configurable.
You can read more here:
http://store.parametricparts.com/store/p10/CURVED-TEXT-1.0
or simply load up the document directly, here:
https://cad.onshape.com/documents/cfec40e2b66bb4ddb2f3414b/w/24132f252a02825eb0606641/e/7a70ac021729253c4df9d213
Although this is an older post, it is still relevant as the function does not seem to have been improved.
However, a quicker way is to 'Fix' the text box corner in place instead of using dimensions.
@brittany_mcgarr
I think that the best way to achieve what you are looking for is to first make the sketch and commit it. Then use "offset surface" (with offset set to 0) to copy the sketch as a bunch of independent surfaces. Then, use "transform" to do a nonuniform scaling of those sketch letters. (you'll probably want to use 1 as the scale factor for the two dimensions that are not stretching, and something larger, maybe 1.1, for the dimension that you want to stretch). Definitely a workaround, but it should get you what you want.
https://cad.onshape.com/help/Content/offset_surface.htm
https://cad.onshape.com/help/Content/transform.htm
Jake Rosenfeld - Modeling Team0 -
Oops! I didn't realize how old this post was. But maybe this will help you @josh_deetz if you were indeed looking for the same functionality.
