Mate two parts
shai_perednik
Member Posts: 56 ✭✭
I'm trying to mate a shaft to a mount and no matter how I mate them, the parts are always 45deg off and the screw holes don't line up. Someone in the past had suggested rotating one of the parts which works as pictured below:
But then breaks when it's brought into the final assembly:
Here's the two parts for reference. The center of the shaft and the 4 screw holes should always line up and never move. (like pictured in the 1st image)
I did try to fasten mates, but I get an error that I violated the assembly.
Thank you for the help!
awesome, trying that.
The doc is public @ https://cad.onshape.com/documents/14f3d01d62b5237f728896c5/w/40e0afc950b8ca0dfecf9ef8/e/1fc83dcbe37b9a246136f7195
Do you mind making it public or sharing with me so I can take a look?0
You need to add one fastened mate, then edit a mate connector from one part or the other.
2 -
The doc is public @ https://cad.onshape.com/documents/14f3d01d62b5237f728896c5/w/40e0afc950b8ca0dfecf9ef8/e/1fc83dcbe37b9a246136f7195 -
Ethan's suggestion worked perfect! Thank you!0
