Multiple versions in one document
bert_fourie
Member Posts: 103 PRO
in General
Sometimes when yo are developing a design it is handy to overlay a previous version of the same drawing over the latest version. is there a way of doing that?
Also, in drawing it is sometimes desirable to compare old and new - how ca hat be done?
Comparing
Onshape provides a mechanism for graphically and discretely comparing versions and workspaces. You can compare any combination of the two.
Access the Compare action from the drop-down menus in the Versions and history flyout:
How it works
When you open the Versions and history flyout, the currently active workspace or version is highlighted (this is referred to as the Base).
To compare to another version or workspace (the Target), click the menu arrow beside the Target and select Compare, as shown above.
What you see
By default, Compare shows:
What you can do
Comparing Assemblies is not yet supported.
Visualize more of the Base features by sliding the circle towards the Base label:
Visualize more of the Target features by sliding the circle towards the Target label:
Interpreting the lists
The list comparing features or Part Studios between the Base and Target uses the following icons to denote differences:
Note that Compare is only for viewing differences. No action can be taken in this view to revert changes or restore to a previous point in time. For those actions, open the Versions and history flyout
