Multi tasking on ISO
john_doubledayjohn_doubleday Member Posts: 58 ✭✭
I have Version 9.3.2 iSo and cannot 'activate' the right hand arrow. this would be great for teaching Onshape. Do others have this problem?
    Hi @john_doubleday what device are you using? True multi-tasking only works on iPad Air 2 and iPad Pro - this is true for all apps not just Onshape. If you have one of those devices, you have to swipe from the right.
  • john_doubledayjohn_doubleday Member Posts: 58 ✭✭
    Thanks Neil,
    Ah maybe as I believe i have just a straight iPad using iso 9.3.2 . Pitty as the new feature would be a great tool. Might have to ask school if I can upgrade, if my students have the modern versions...ipad Air
  • rbaekrbaek Moderator, Onshape Employees, Developers Posts: 77 image
    Thanks Neil,
    Multitasking is available for iPad Air, iPad Air 2, iPad Pro, and iPad mini 2, 3, and 4. So long as those device have iOS 9 or above, they will be able to do multitasking.
