loft problem
kees_ouderkerk
Member Posts: 5 ✭✭
Hello everybody :-)
A few days ago i started modeling this helicopter ( http://cdn-www.airliners.net/photos/airliners/8/7/0/0532078.jpg?v=v20 ) in Onshape. During the construction of the cockpit the loft function was very helpful to me. Untill..... i had to close the holes (wich you can see on the picture) with a curvature surface. Then i found that the the loft function doesn't offer a possibility to create a surface which is curvature to both the profiles and the guides. Filling these holes with a non curvature surface seemed to be the sollution but this caused problems when i tried to thicken the non curvature surfaces. So.... Is there maybe a workaround for this problem?
Thanks in advance,
Kees
Thanks in advance,
Kees
Narayan_K
Member Posts: 379 ✭✭✭
@ kees_ouderkerk , As a work around you can use replace face option to match the faces.
To more details you can refer below document,
https://cad.onshape.com/documents/578c7bbce4b0483587d2917d/w/28b31e6894e18f0a324b9433/e/f699f81fc4516a09975df4e6
Hope this will help you.
5
I already tried this. but then (after thicken the surfaces) i got this:
(as you can seen the surface doesn't fit to the other surfaces
https://cad.onshape.com/documents/578b4e58e4b0e425c1efa814/w/6a82ae2fffcd4df7a34ff879/e/7e755299560cd7f07ef75e24
https://cad.onshape.com/documents/578ba8f2e4b02dc672b7f454/w/0cb02f229513bf48be1095ac/e/94241fd2f73922ba01a6e887
(a) I'd be tempted to abandon the thicken method. Instead use a boolean to cut your surface into a solid to get a continuous smooth part.
(b) Just model one half, then use shell to hollow it out (if needed) then mirror to slap the other half on.
Cheers,
Owen S.
HWM-Water Ltd
Gr,
Kees
