Appearance issue?
kirk_2
Member Posts: 34 ✭
I created a part studio with 3 parts (all are similar but created with mirror and rotate). When I select one and set a color from the appearance dialog, all 3 change color. I expected only the selected part to change.
As always, my use of OS is in playing around mode, rather than any specific need on my part.
What I mean is, if I want a part to look like it is made from a specific material such as steel or aluminium, will I be able to?
I actually like the system as it stands, and I'm sure that with enough trial and error I could get an appearance to suit, however I wouldn't want to have to remember or record every set of numbers for each individual appearance that I liked.
1) Materials choice - this can be used to influence model rendering, and used in calculations for Mass Properties or sharing with a photo-realistic renderer etc.
2) General appearance customization - this can be huge range of customizations from things like the color cycles used when no material is specified (the algorithm @Brian Drake mentioned) to things like text colors and size for the feature list etc.
