Couldn't able to find the newly created document using POST request.
manokar_munisamymanokar_munisamy Member, Developers Posts: 6
I am developing a plugin in vb.net which is connected to onshape application ,where i need to create a new document. I have sent the POST request with value like "https://partner.dev.onshape.com/documents/" with {'name':'asdasd'}. I have got the response as below
{StatusCode: 200, ReasonPhrase: 'OK', Version: 1.1, Content: System.Net.Http.StreamContent, Headers:{  Connection: keep-alive  Vary: Accept-Encoding  X-No-Cache: 1  X-Frame-Options: SAMEORIGIN  Strict-Transport-Security: max-age=31536000; includeSubDomains  X-Content-Type-Options: nosniff  X-XSS-Protection: 1; mode=block  Content-Security-Policy-Report-Only: object-src 'self'; report-uri /api/csp  Date: Wed, 10 Aug 2016 08:16:42 GMT  Set-Cookie: _u=websvc-fecfa158; Path=/; Secure; HttpOnly;  Server: nginx  Content-Length: 1032  Content-Type: text/html; charset=utf-8}}
But I couldn't able to find the newly created document in the OnShape workspace. Could you please help me to find the document. Is the document is created or not?
  • manokar_munisamymanokar_munisamy Member, Developers Posts: 6
    I have solved the issue with posting the correct POST request with json input as object. Thanks
