loft did not regenerate properly cannot use faces or regions with inner loops as profiles
I'm trying to loft a shelled (tube) to a smaller diameter circle . I get the error "loft did not regenerate properly cannot use faces or regions with inner loops as profiles" probably because I am unable to select just the OD of the tube as the profile to loft. I am able to select the OD in all other functions EXCEPT loft. is this a bug or feature, and what am I doing wrong. (I initially was trying to shell a formed solid into a tube but was not able to see some internal segments to select them to shell so had to roll back and shell my way out) Also, how do I make all the segments of this the same color:
https://cad.onshape.com/documents/0c0abff3e620cfd6f7687db0/w/63f09bb442585f39287cb605/e/0cd0fd5d5c3b448ea1fc593f
https://cad.onshape.com/documents/22121e19f0b44192dd827fc3/w/9b38613ad8f2222d4f5c1020/e/ca86418511ed52840bfc4768
Thingiverse:
Customizable Cube Gears by emmett - Thingiverse
My doc:
https://cad.onshape.com/documents/455938b08b626a0a124e8512/w/03acb07e6f50bce12dc60f8c/e/e949e09c2b009df459c3ce63?renderMode=0&uiState=665770995a3276680b8e9468
https://cad.onshape.com/documents/4017fe3a26f0c01b8ece2718/w/072738ce01c50f61ca864bf0/e/a0c07e9b77fdb2b4df9ad301
