INSTEP
Is INSTEP the correct software to use to convert point cloud data to STEP files so that is can be imported into ONSHAPE and modeled
  • Jason_SJason_S Moderator, Onshape Employees, Developers Posts: 224
    Hi Andrew,
    Yes, INSTEP is a great solution to fix your point cloud models and import them into Onshape. Since INSTEP is available through our AppStore, the transfer of documents from INSTEP to Onshape is straightforward.
    Thanks, good luck, and let me know if you need any help!
    Jason
    Support & QA
  • joe_dunnejoe_dunne Onshape Employees, Developers, csevp Posts: 198
    Instep is excellent.  Also Power Surfacing has some very good point cloud to Surface tools.
    Joe
    Joe Dunne / Onshape, Inc.
    @andrew_hicks, Along with Instep you can use STLWorkbench and power surfacing to convert point cloud data to STEP files. All these apps are available in Onshape AppStore. STLWorkbench fixes the problem of STL file and convert them into printable form. INSTEP transfer the documents from INSTEP to Onshape directly however in STLWorkbench user need to download document from STLWorkbench and then import into Onshape.
  • bert_fouriebert_fourie Member Posts: 103 PRO
    I wonder if there is an update to this. I would like to import a Lidar scan cloud file in dxf format. It is not successful. I cannot find INSTEP in the App store.
