making 'linear pattern' work
I am trying to use 'linear patter' for the first time. I looked in 'help' and followed directions EXACTLY as they are shown, and get nothing, it won't work and just says check input. It is a simple extruded cylinder located on a flat face. How hard can this be. I've done it a zillion times in SW, and its easy!!!!!
  • mahir
    mahir Posts: 1,324 ✭✭✭✭✭
    If you share the doc with copy permissions, someone can take a look.
  • @gilbert_ransley Are you doing a face, feature, or part pattern?  My guess is you are looking for a feature pattern.
    You should be able to select Feature Pattern from the list, then select the extruded cylinder feature from the feature list just like SolidWorks.
