Multiple use for imported parts
Dylan_Stewart
Member, Developers Posts: 107 PRO
Okay, I'm going to try and explain this to the best of my ability (<--Feel like I've said that before??
So I have a profile that I am importing in to a FS..... easy enough...
Then, I turn it in to a function.
So my question is can I use this to extrude the imported profile PS while using it as a function?
I have tried and I'm not having any luck....
Really, I would like to reduce the amount of options in UI and I thought I might be able to get 2 birds with 1 stone here.
export enum sealantProfileID
annotation { "Name" : "1/16 inch" }
F72Dq47pUtYbudg_0,
annotation { "Name" : "1/8 inch" }
Fe9DDixnU9zeHn2_0,
annotation { "Name" : "1/4 inch" }
FCofrjEa8xpUaY3_0
export function evsealantProfileID(value is sealantProfileID)
return {
"F72Dq47pUtYbudg_0" : .0625 * inch,
"Fe9DDixnU9zeHn2_0" : .125 * inch,
"FCofrjEa8xpUaY3_0" : .25 * inch
}[value as string];
}So my question is can I use this to extrude the imported profile PS while using it as a function?
Digital Engineering
You can use that enum to indicate both a sketch id and an extrude thickness via that function, yes.
Can you share a document to give us a better idea of what you're trying to do?0 -
Thank you @kevin_o_toole_1
I got it figured out. I was actually calling the wrong sketch in my FS.....Digital Engineering0
