Autocreation list of custom features by script.
max_borsh
max_borsh Member, Developers Posts: 14 ✭
Hi Everybody.
Supposing I have some custom features that I need to invoke in specific scenario to create my entire Part.
Is there any way to write a script that could call features in a particular order(i.e. by scenario)?
I know that I can just create another feature and call all functions (custom features) that I need to create Part.
But in this case I'll get only one feature in my feature tree (in Part Studio) instead of the list of called features.
For clarity, get some images:
I want to take list of features (then I'd get some changes at any feature):
Instead of this:
So, I just want to have the way where features will be constructed automaticaly,
not manualy (call each feature by clicking the one in list of custom features).
  • Dylan_Stewart
    Dylan_Stewart Member, Developers Posts: 107 PRO
    Yes, it is very possible.
    This sounds very similar to what I am doing.
    If you want, you could share the document with me and I can help out.
    Digital Engineering
  • Dylan_Stewart
    @kevin_o_toole_1
    Hmmmm... Maybe I misunderstood what is trying to be accomplished.
    @max_borsh  I would listen to Kevin over myself (for obvious reasons)
    My apologies for spreading false information. But, if it's a matter of all the parts talking to each other and swapping out parts and changing each part, then why is it not possible? The reason I ask is that I am working on a feature that constructs multiple different parts and each one of them can be changed and modified.
    Digital Engineering
  • kevin_o_toole_1
    @Dylan_Stewart
    If I understood @max_borsh correctly, he's trying to make a single FeatureScript which, when run, leaves multiple features in the feature tree as outputs. This is something a macro language can do, but FeatureScript can't.
    The things you just described do sound possible.
  • Dylan_Stewart
     Oh okay, now I see. Sorry for the misunderstanding.
    Digital Engineering
  • robert_morris
    robert_morris OS Professional, Developers Posts: 176 PRO
    @max_borsh
    One alternative that might work for you is to create a "template" document that has a Parts Studio for each scenario with just the base features in it (the ones you would want to have in your script). That way you only have to create the features once and you can copy the Parts Studio around to other documents when you need to.
    When you want to create a new document that uses one of those scenarios, just right-click on the template Parts Studio tab and select "Copy to clipboard". and in the new document, click the '+' button and select "Past tab".
  • owen_sparks
    Forgive me for being lazy and just asking rather than trying it but could you use variables declared in the part studio (by humans, not variables declared in featurescript code) as inputs to list of sequential featurescript features?
    eg variables user declares:-
    #BoxWidth
    #BoxHeight
    #BoxDepth
    then run featurescripts:-
    Build_Me_A_Box
    Build_Me_A_Lid
    Build_Me_A_Handle
    Not linking the fs to the variable in code but by having the user type "#BoxWidth" into the user interfaces of each.
    We'd then having the option to change multiple parts generated by separate featurescripts from one dimension.
    Cheers,
    Owen S.
    HWM-Water Ltd
  • kevin_o_toole_1
    @owen_sparks You can read any variables set by users or via getVariable, because internally, the Onshape variable feature is just calling setVariable).
    One tricky thing is documenting the fact that your features require such a variable to be set (so a user of the feature doesn't get confused if they forgot that step or spelled the variable name wrong).
    A possibly better interface could be a "setup" feature which takes in a length, width, and height (possibly building the basic thing), and also sets the three variables with setVariable. Then downstream features can access those values, and the user has a mistake-free dialog in which to enter them.
  • owen_sparks
    Thanks @kevin_o_toole_1 makes perfect sense.
    This highlights the sense of your features, and fs all using same native language rather than bolt on afterthought macros.
    I think we're talking at cross purposes here.
    The workflow I was hoping to illustrate was a method to have a user run sequential featurescripts (possibly from different developers even) driven from some variables set at the beginning.  Thus creating feature tree entries for each step as per the original poster's intent.  No programming would be required for a user to achieve this.  (An option to enable the user to pick a pre-declared variable from drop down list would help here.)
    That's elegant :-)
    Cheers,
    Owen S.
    HWM-Water Ltd
