How to delete a label definition ?
jmproulx
Member Posts: 3 PRO
If you made an error in defining a label, how can you modify or delete it ? Also, how can you detach it from a document ?
For rename, right click on label name in left bar and choose rename (other choices: create new, delete)
To add / remove labels for doc, right click doc on list -> labels -> add/remove checkbox beside label name.
//rami5 -
Screenshots for my previous post.
RMB Label on list:
RMB document on list:
Choose labels using checkboxes:
//rami7
Not sure on that, If you can't do any of this I think you should be able too. I am prone to typo's and alway change my naming criteria's as better idea's come along so would expect to be able to edit my tag names.
//rami5 -
RMB Label on list:
//rami7 -
@brucebartlett Isn't it nice when you can just imagine how you would use something and when you sign in, it works exactly as expected
//rami0
