How to put a line through a point along an axis?
rabbinnrabbinn Member Posts: 1
As shown here.
I want the blue line to go through the yellowish dot on the arc. The blue line and the grey line in the x-direction is created on the top sketch, but the arc is slightly under the top sketch layer.
    edited September 2016
    If the yellow point is on the sketch plane, you can use a pierce relation (or coincident). Otherwise, the best you can do is a coincident relation that will overlap the line with a projection of the point, not the point itself. If you want to be sure the line goes through the point, you can create a plane parallel to Top at that point. Then sketch the line on that plane.
