Create sketch in middle of part
Lee_Hesketh
Lee_Hesketh Member, Developers Posts: 148 ✭✭✭
Hi all. I have a script where the user selects a face, then using qConvexConnectedFaces twice to select the ends. I have then found the midpoint of each of those faces and used them to find the midpoint of the part. What I need to do is create a plane at that point parallel to the end faces and then create a sketch. How could I do this?
Also, how could I implement the midplane feature from the plane command?
Thanks
Lee Hesketh
There are 10 types of people in the world. Those who know binary, those who don't and those who didn't expect base 3!
  • ilya_baran
    Also, keep in mind that in FS you don't need to actually create a construction plane to sketch on -- you can pass a plane directly to newSketchOnPlane (that will, in fact, likely make things easier because then the coordinate system of the sketch is the coordinate system of the plane).  See https://cad.onshape.com/FsDoc/library.html#newSketchOnPlane-Context-Id-map
