Movable Wall Base
  • jakeramsleyjakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 668 image
    Looking at your document, your sketches have dimensions on them.  To add more, while in a sketch use the dimension tool (shortcut 'd') and then select the entities in the sketch you want to dimension.  If you select a line it does a length dimension, two points does a distance dimension, two parallel lines does a distance dimension, two non-parallel lines gives an angle dimension, etc.
    Jake Ramsley
