Will I loose my models?
I find that I can no longer justify the monthly cost of Onshape and must cancel my subscription plan. I will however need to come back to the models I have created at some point in the near future to make more edits. At that point I will be happy to resubscribe.
If I cancel my plan are my models deleted? Or is there a way to export the models in their Onshape format so I can reload them in the future? I understand that I can export them in other formats but that is not a good solution for pieces I need to continue work on in the future.
  • øyvind_kaurstadøyvind_kaurstad Member Posts: 234 ✭✭✭
    There is no native Onshape format, but I'm pretty sure nothing happens to your models. You will be able to view them, but not edit them. And if you later resubscribe, edit capabilities will be restored.
  • dave_cdave_c Onshape Employees Posts: 42 image
    That is correct.  Nothing happens to your models.  They remain private and are viewable.  When you resubscribe you can edit them.
