Improved Corner Overcut Script
jonathon_duerig
PRO
There is now an improved version of the corner overcut script available. The big change is that the UI is now much less fiddly. Just pick a diameter and select the edges you want to be overcut and cylinders will be cut out of them. It works just like the fillet tool now.
Take a look here (includes documentation):
https://cad.onshape.com/documents/92ffa0438c5a36d135c0d102/w/8985aa3f7ecdca842d07658c/e/2e948c6e1fea4a86aca4affa
For those who don't know, corner overcut is important for CNC routing where the circular end mill can't cut sharp internal corners. You use corner overcut to cut out a bit extra at the corners so that joint edges can sit flush to one another.
-D
-D
3
