Google Chrome WebGL Problem
Tobes49
Tobes49 Member Posts: 3 ✭
edited November 2016 in Community Support
Hi
Over the weekend my computer was reporting -
It looks like your browser doesn't have WebGL enabled.
I tried my laptop and this all works perfectly
On the non working computer, I tried reinstalling chrome and the Graphic drivers - this didn't cure the problem
http://webglreport.com/ - reports:
: This browser supports WebGL 1, but it is disabled or unavailable
Ive done some searching the testing - checked the flags in google and they all look correct
Chrome://gpu Click here for report  States Webgl is hardware accelerated but has lots off memory errors at the bottom
Now Ive tried 5 computers now and 3 are fine and 2 don't work (They all did work before)
The 2 that have packed up had the Nvidia 342 update before this happened. (Not sure if this is the problem or not)
I have uninstalled all the graphic drivers and this still has not cured the problem
Can anyone help with this please?
Toby
  • viru
    @Tobes49,  What you do is to right-click the Chrome shortcut (could be in the start menu or on the desktop), and go to properties. Then you add the quoted command flag after the ending double quote sign (i.e you tag it at the end of whatever is there) in the target box, like so:
    Target:
    --disable_chromium_framebuffer_multisample
    Please remember that the fix is then only applied to this specific shortcut. If you have multiple shortcuts to Chrome (for instance both in the start menu and the desktop), it will only work for those you have edited. Give special thanks to øyvind_kaurstad because this solution provided by him.
  • Tobes49
    Target:
    I've just tried this and this doesn't fix the problem. Just to double check I created a new shortcut on the desktop and edited this one.
    Thanks for the info
  • Paul_J_Premakumar
    Paul_J_Premakumar Member, Onshape Employees Posts: 238 image
    Hi Tobes49,
     - What version of Chrome and Operating system are you using?
     - Are the versions of Chrome the same on the computers which are working and the ones which are not working?
     - Can you paste the errors you are seeing?
    There has been a recent bug in Chromium and here is the Chromium bug report : https://bugs.chromium.org/p/chromium/issues/detail?id=656989 . You may want to check if this is the same as what you are experiencing.
    While we figure out the issue, please consider using another supported browser such as Firefox or Safari.
  • Tobes49
    Hi Paul
    Ive been doing some more testing and think it is the Chromium bug,  (It has only effected my computers with Nvidia graphic cards for some reason?)
    PC is Core 2 Q8400 with windows 10, Chrome is 54.0.2840.99 m, Nvidia GeForce 8400GS
    Chrome were different versions - all started to happen when the Nvidia updated to version 342.00
    Error just appears at the top off the "loading workspace" page with "
    It looks like your browser doesn't have WebGL enabled"
    I have downloaded the
    chrome canary edition with this installed everything works again.
  • lougallo
    lougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,021 image
    @Tobes49 it is indeed a chrome bug where some cards are being blacklisted.  You can also type in
    chrome://flags<br>
    Then enable "Override software rendering list".. The nice part about Chrome Canary is it can be installed side by side with another chrome channel (stable/beta/dev)
    Lou Gallo
    Sr. Director of Product Definition. UX and Support
