Easyway to Draft multiple faces
aaron_skidmore
aaron_skidmore Member Posts: 34 ✭✭
Hi have a model with embossed lettering that has many faces, I want an easy way to draft all faces without having to individually select each face.
face.jpg 263.5K
  • brucebartlett
    With the draft command try a side view and window select across all the side faces, first clicking from the bottom rh to top lh corner. Ensure to only pass through the side faces
  • _Ðave_
    _Ðave_ Member, Developers Posts: 712 ✭✭✭✭
    edited November 2016
    @aaron_skidmore use the draft option in the extrude feature that you used.
