So if i import a file how can i add it into an assembly with other parts that i created?
matthew_fox953
Member Posts: 1 ✭
It doesnt seem to want to work for me
bradley_sauln
Moderator, Onshape Employees, Developers Posts: 373
If the part/file translates you should be able to insert it into the assembly: https://cad.onshape.com/help/#insertpartorassembly.htm?Highlight=assembly insert
If the imported file does not translate there may be a broken surface in the model. You can file a feedback ticket and share the document with support to get some further help5
Twitter: @bradleysauln
