How do I do multiple distance mates in Onshape?
asyraf_saaet
asyraf_saaet Member Posts: 3 ✭
edited December 2016 in Community Support
I'm trying to mate a specific part on a base plate where the precise distance from the datum is key. Therefore, I'll have to use 3 mates to lock it in place. On the plane is easy but for the X and Y is not as clear cut as in Solidworks.
  • viru
    @asyraf_saaet, If you want to supply an offset distance, check Offset and supply a distance. Fastened mates can offset the entities along any combination of the three axes:
    planar-offset example
    Offsetting entities from one another during assembly is available for the following mate types:
    • Planar offset - Along the Z axis
    • Slider offset - Along the X and Y axes
    • Revolute offset - Along the Z axis
    • Pin slot offset - Along the Z axis
    • Fastened offset - Along the X, Y, and Z axes
    You can also drag the entities and observe the distance values in the graphics area. These can help determine the specific values to enter in the dialog.
    Please refer below video for more detail.
  • asyraf_saaet
    Thanks guys. But what if I want to mate the part in X direction from face 1, and Y direction from face 2. Is there anyway I still can do that?
