PDF Export of 2D drawings results in LARGE file
kvdmolenpkvdmolenp Member Posts: 28 ✭✭
Hi,
When I export certain 2D drawings to PDF, they become 5mb. Some others (not much simpler drawings) are under 100kb.
Now I can't send multiple PDF's in one email because it exceeds 20mb quickly,
Perhaps has to do with some history (reload part, edit drawing).
Any ideas to reduce the size?
Thanks!
Klaas
    edited December 2016
    I believe there was a similar post citing particular fonts as causing an issue.  I'm sure an OS person will be along in a few hours once those blasted Americans have woken up and got out of bed... ;)
    Owen S,
    HWM-Water Ltd
  • Rob_CampbellRob_Campbell Member Posts: 2
    I just encountered this and it is insane. I thought it must be creating 3D PDFs!
    "Reprinting" it with another PDF tool (I use Foxit PDF viewer) creates a much smaller file with no resolution loss (it's still a vector-based file).
    Apparently, the default setting in SolidWorks is to include fonts as well, but for whatever, the resulting size of the PDF is 50-100X smaller. So either SolidWorks is not really embedding fonts, or there is a more elegant way to just embed what is necessary without the file ballooning.
    I just re-read your response, @pete_yodis, and it sounds like OnShape may need to consult with a developer with more expertise in PDF, because my SolidWorks-created PDFs are searchable, look great, and - again - 50-100X smaller than OnShape PDF files.
    Rasterizing the print sounds like a very poor way to address this.
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 577 image
    @Rob_Campbell There is definitely room for improvement when fonts are embedded.  That will be improved as we move forward as well.    We will be reducing the number of scenarios when a larger PDF file is created.  Our platform is different compared to a desktop installed system which sometimes makes these issues a little different.
