API OAuth support
Do your OAuth implementations follow the spec? It appears you followed the pattern but not the spec. Perhaps not even. I'm not sure if you are using Oauth1 or Oauth2? My use case only requires API access from my external application. If we were using OAuth2 that would require me to acquire an access token to pass in the auth header of all requests. Since it appears you require request signing, parameter order and canonicalization I'm assuming it's OAuth1. However it doesn't seem to follow that spec either based on your header formats and other inconsistencies. Maybe I'm wrong? It would appear I can't use any off the shelf clients that support oauth1 or oauth2 because you don't follow either of these specs?
The Onshape OAuth2 implementation is currently not meant for end-user accounts, but for server-to-server application authorization as needed by Onshape Appstore applications (https://appstore.onshape.com).
This implementation follows the typical "three-legged" OAuth2 use cases as specified by RFCs 6479 and 6750. Specifically, the authorization code grant, access and refresh token workflows described by RFC 6479, and the conveyance of tokens in HTTP(S) requests as specified by RFC 6750.
I'm happy to go into these and related subjects in further detail. Depending on your interest level, you may also be interested in our partner program (https://www.onshape.com/partners/apply). If you only want to enable some API access for your external application for your own account, in addition to our OAuth2-based solution, we may be able to help you out with alternative solutions as well.
Regards,
John de Freitas
