variable available in multiple part studios
I don't really know how to formulate my problem correctly, so i'll just explain the situation.
I enjoy building wooden furniture (as a hobby). Depending on available material, I would like to have some variables I could use for entering the basic dimensions of the material (e.g. thickness of plywood sheet, board sections...), so when using different material, I adapt the variables and the model adapts accordingly. This works fine if everything is in one part studio.
Now, how do I create variables valid for all part studios in a document, as I would like to use multiple part studios and don't want to have to enter everything again and again (with the risk of missing one)?
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,252 image
    While we don't have global variables yet, you can work around this with FeatureScript (if you're not afraid of a little code): write a custom feature that sets the variables to the values you want (using the setVariable call) and then have that custom feature be the first feature in all of your part studios.
