How to create a query that will select a specific edge of a part?
cory_isaacson
Member, Developers Posts: 43 PRO
I have a part that is a rectangle that is 1/4" thick after extrusion. In FeatureScript I need to select the corner edge (the 1/4" thickness, no other edges). This is so I can keep the part flat but Fillet the corner (just the vertical edge). I can do this manually be don't know how to create a FS query to do the same thing.
If someone could provide a FS query example to do this that would be great.
Thanks Ilya. That's perfect and it works now!
A tutorial on how to do queries would be incredibly helpful, it's not altogether obvious how they work from the documentation and examples. I might be able to help with this if I could work with you on this. I've been a software developer all my career, and an instructor, so this type of documentation would be something I could help with.
5
Hi @cory_isaacson I am also learning the feature script programming through the feature script documentation. So, I may not precisely correct in this answer. Try following lines just for a reference. It is not a complete program. You can modify it as per your requirement.FeatureScript 464;import(path : "onshape/std/geometry.fs", version : "464.0");annotation { "Feature Type Name" : "Extrude1" }export const extrude1 = defineFeature(function(context is Context, id is Id, definition is map)precondition{annotation { "Name" : "My Query", "Filter" : EntityType.EDGE, "MaxNumberOfPicks" : 1 }definition.myQuery is Query;annotation { "Name" : "My Length" }isLength(definition.myLength, LENGTH_BOUNDS);}{opExtrude(context, id + "extrude1", {"entities" : qCreatedBy(id + "extrude1", EntityType.BODY),"direction" : evOwnerSketchPlane(context, { "entity" : qCreatedBy(id + "extrude1", EntityType.BODY) }).normal,"endBound" : BoundingType.BLIND,"endDepth" : 1 * inch});opThicken(context, id + "thicken1", {"entities" : qCreatedBy(id + "extrude1", EntityType.BODY),"thickness1" : 0.1 * inch,"thickness2" : 0.1 * inch});opBoolean(context, id + "boolean1", {"tools" : qCreatedBy(id + "extrude1", EntityType.BODY),"operationType" : BooleanOperationType.UNION});});
Highlighted lines in Italic and bold format are query for edge selection. I am still in the learning phase of FS programming. You can also share your ideas if something needs to be corrected in above lines.
Thanks0 -
I think the OP is asking for a query rather than for the user to do a selection. I can't picture from the description which exact edge is required (without a document link), but I can suggest computing a 3D point that should be on the edge and using qContainsPoint or using something like qSmallest and qFarthestAlong to filter out the qCreatedBy edges.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc1
Thanks, I am close now, this almost works. The section with the comments: // This resolves to nothing is not finding the edge between the two points (or all the edges on the part). I checked and my points are both correct and valid (they are highlighted when I debug). FYI, my logMessage function just calls debug with some other text in println to make it easier to read.
So the question now is: How can I select the edge between the two points?
// Query for the part.
var partQuery is Query = qCreatedBy(id + value.extrudeName, EntityType.BODY);
logMessage(context, "partQuery", partQuery);
// This resolves to nothing.
var linesQuery is Query = qGeometry(partQuery, GeometryType.LINE);
logMessage(context, "linesQuery", linesQuery);
// Build the vector for the bottomUpperLeft and topUpperLeft points.
var bottomUpperLeft is Vector = vector(value.xLeft, value.yUpperLeft, value.planeOffset);
var topUpperLeft is Vector = vector(value.xLeft, value.yUpperLeft, value.planeOffset + value.partThickness);
logMessage(context, "bottomUpperLeft", bottomUpperLeft);
logMessage(context, "topUpperLeft", topUpperLeft);
// Build the full query using qContainsPoint. This returns the entire body.
var upperLeftPointsQuery is Query = qContainsPoint(qContainsPoint(partQuery, bottomUpperLeft), topUpperLeft);
logMessage(context, "upperLeftPointsQuery", upperLeftPointsQuery);
// Query for the line between the points.
var upperLeftEdgeQuery is Query = qGeometry(upperLeftPointsQuery, GeometryType.LINE);
logMessage(context, "upperLeftEdgeQuery", upperLeftEdgeQuery);
Here is the debug output:
partQuery
debug: Query resolves to 1 bodies
linesQuery
debug: Query resolves to nothing
bottomUpperLeft
debug: Vector (-0.0381 meter, 0.2921 meter, 0 meter)
topUpperLeft
debug: Vector (-0.0381 meter, 0.2921 meter, 0.006350000000000001 meter)
upperLeftEdgeQuery
Result: Regeneration complete
The problem is that querying for a body doesn't query for all entities owned by the body (i.e. its edges, faces, etc.). So if you replace partQuery with qOwnedByBody(partQuery) it should work.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
5 -
OK, now the query is correct (I see the proper edge in the highlight when debugging). But the fillet does not do anything. Can you see why it doesn't work?
// Query for the part.<br> var bodyQuery is Query = qCreatedBy(id + value.extrudeName, EntityType.BODY);<br> logMessage(context, "bodyQuery", bodyQuery);<br> <br> // Get all components owned by the bodyQuery.<br> var partQuery is Query = qOwnedByBody(bodyQuery);<br> // logMessage(context, "partQuery", partQuery);<br> <br> // var linesQuery is Query = qGeometry(partQuery, GeometryType.LINE);<br> // logMessage(context, "linesQuery", linesQuery);<br> <br> // Build the vector for the bottomUpperLeft and topUpperLeft points.<br> var bottomUpperLeft is Vector = vector(value.xLeft, value.yUpperLeft, value.planeOffset);<br> var topUpperLeft is Vector = vector(value.xLeft, value.yUpperLeft, value.planeOffset + value.partThickness);<br> logMessage(context, "bottomUpperLeft", bottomUpperLeft);<br> logMessage(context, "topUpperLeft", topUpperLeft);<br> <br> <br> // Build the full query using qContainsPoint. This returns the entire body.<br> var upperLeftPointsQuery is Query = qContainsPoint(qContainsPoint(partQuery, bottomUpperLeft), topUpperLeft);<br> logMessage(context, "upperLeftPointsQuery", upperLeftPointsQuery);<br> <br> // Query for the line between the points.<br> var upperLeftEdgeQuery is Query = qGeometry(upperLeftPointsQuery, GeometryType.LINE);<br> logMessage(context, "upperLeftEdgeQuery", upperLeftEdgeQuery);<br> <br> // Perform the fillet.<br> opFillet(context, id + "fillet1", {<br> "entities" : upperLeftEdgeQuery,<br> "radius" : value.filletRadius<br> });
You are right -- that is a gap in the docs and tutorials -- and it is something likely to be unfamiliar to people of all backgrounds. We'll put something together and ask for your feedback. @kevin_o_toole_1
