set field default to variable
I am using the FeatureScript "Wiring" provided by Onshape to do a bunch of routing. I want the size of the wires to be dependent on a variable, #WireDiameter. I would like for this variable to be the default value in the "diameter" field, so I don't have to copy it in every time. Is there any way to have the default values given in "isLength" be variables, rather than numbers?
  • Not as such. That default value is stored statically as part of the custom feature type, and not recalculated dynamically in an environment that knows about external variables.
    A possible workaround is to copy the wiring feature and add an editing logic function that:
    • Is only called on creation (i.e. leaves out the isCreating parameter)
    • Checks the context for a #WireDiameter variable (via getVariable)
    • If that variable exists, sets the "definition.diameter" field to its value
    If coding this sounds worthwhile to you, let us know if you encounter any issues!
  • Thanks for the suggestion, I will try that.
    One other issue that came up -- I noticed that in that feature if I set Starting Straightness or Ending Straightness to a variable, and then I change that variable, the displayed length of the wire does not update. To get it to update, I have to change it, and then change it back to the variable, and then it updates the displayed length. Is there a way to get it to update automatically when the variable value changes?
  • I noticed that in that feature if I set Starting Straightness or Ending Straightness to a variable, and then I change that variable, the displayed length of the wire does not update. To get it to update, I have to change it, and then change it back to the variable, and then it updates the displayed length.
    That's a bug in the Wiring feature.  It only updates the length in the editing logic function, so if that doesn't run the feature name won't update.  Using setFeatureComputedParameter to set 'length' to the appropriate value at the end of the feature should fix the problem.
  • ilya_baran
    ilya_baran Posts: 1,273 image
    It should also be possible to set an expression of a parameter from an editing logic function: instead of using the value of the variable, try setting the parameter to the string "#WireDiameter".
