How to made hex hole to hex shaft
Hello,
When I'm trying to mate a wheel with hex hole to hex shaft with Cylindrical Mate the hex hole and shaft are not align.
I tried to use Slide Mate but it did not work too.
I'll appreciate any advise.
https://cad.onshape.com/documents/1ed55780854c84f63aaf31aa/w/d952c86677aaa67a965a70e4/e/c9e0ee041f155e5c9709e856
Tnx,
Kobi
Tnx,
Kobi
Your rod was modeled at an angle in the part studio, so by default any mate connectors put on it would be at a strange angle. To counter this you can use the 'realign' option in the mate connector to line it up, then use a slider mate. Make a copy of this and double click 'Mate Connector 3' to see what I mean:
https://cad.onshape.com/documents/588626c26b86830f7064937c/w/9679f8ca5cfe7f607c156bf8/e/a11b2efa0769134d31119f53
You wouldn't want a cylindrical mate here because this allows rotation in addition to the slide.
