Fully Constraint bug
rune_thorsenrune_thorsen Member Posts: 7
I have this simple sketch
As its black it's fully constraint, i.e. zero degrees of freedom. yes?. No
I add a perpendicular angle (take away 1 DOF) here and it becomes as I want it. The paradox is that if it was fully constraint before then it should become red for overdefined. Or it should not have been black before as fully constrained.
    if possible, make your document public and share it here.  I am sure you will get response once others can analyze it.
    www.accuratepattern.com
  • rune_thorsenrune_thorsen Member Posts: 7
    Sorry, I did a complete redraw to fix the problem so I cant find the version anymore. Try to replicate when I got time left
