@opDraft: Map does not contain field 'queryType'
brian_guan
brian_guan Member Posts: 13 ✭✭
I am trying to use opDraft in feature script but I am getting a weird error:
I don't see anywhere in the documentation what this queryType is in opDraft, so I took a guess a supplied something but the error remains.
Here's the code snippet:
export const XZ_PLANE = plane(vector(0, 0, 0) * meter, vector(0, 1, 0));
annotation { "Feature Type Name" : "BadDraft" }export const BadDraft = defineFeature(    function(ctx is Context, id is Id, args is map)    precondition {    } {        fCuboid(ctx, id + "cube4draft", {                "corner1" : vector(0, 0, 0)*inch,                "corner2" : vector(10, 1, 2)*inch        });        var _qFace = qIntersectsPlane(            qParallelPlanes(qCreatedBy(id + "cube4draft", EntityType.FACE), XZ_PLANE, false),            XZ_PLANE);                    opDraft(ctx, id + "draftRib", {                "neutralPlane" : XY_PLANE,                "pullVec" : XY_PLANE.normal,                "draftFaces" : _qFace,                "angle" : 30 * degree,                "queryType": QueryType.TRANSIENT        });    });
I have created an example public doc to show the problem, can someone enlighten me please?
https://cad.onshape.com/documents/ed5afb001e7acc0bd4c250a9/w/d7e5cbc472f2a9b26248ac1c/e/6053220dd0440a3cad097c32
  • ilya_baran
    ilya_baran Onshape Employees, Developers, HDM Posts: 1,273 image
    This is an unfortunately poor error message on our part.  I believe the problem is that neutralPlane expects a query, but you are passing a plane.  (and it's looking for queryType in the passed in plane and not finding it).  If you pass a qCreatedBy(newId() + "Top", EntityType.FACE) for the neutralPlane, I think it should work.  No need to include queryType in the opDraft definition.  The opDraft documentation has the definition types listed.  Hope this helps.
  • brian_guan
    Thank you, that helped.  Now my draft is working...
