Why can't I remove the parts on particular places?
On this drawing I was trying to remove the bits highlighted in yellow by 'extrude'. But when I clicked on OK it only removed it on the outer sphere. Why is on the inner sphere the bits are not removed? Can someone please tell me how I can fix this problem?
  • noanoa Onshape Employees, Developers Posts: 141 image
    @taichi_yamaguchi in the extrude dialogue, there is a section called "Merge scope." You must choose which parts you want to remove that material from. Alternatively, you can check a box to merge with all parts.
    Noa Flaherty / Customer Success / Onshape Inc.
  • taichi_yamaguchitaichi_yamaguchi Member Posts: 3
    Thank you very much! I've successfully opened through every halls!
