array of queries back to a single query?
johnsogg
I have an array of queries using this:
var edges is array = evaluateQuery(context, edgesQuery);
The `edges` array is then post-processed a bit, which leaves me with an array-of-arrays. I need to use each nested array as input to `constructPath`, but this requires a single query for its input, rather than an array of queries.
Is there a way I can create a new single query out of my array of queries?
Also, unrelated but a question I am dying to find out: is there a way to print the type of an object?
Answering my own question. `var edges = qUnion(lotsOfIndividualQueriesArray)` does the trick.1
Correct regarding qUnion. You can get the object type by printing it out bypassing the toString methods. The output of println("" ~ object) will have that information (try it for a few things whose type you know).Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
