Linear pattern Tool???
ray_sleeperray_sleeper Member Posts: 5
edited February 2017 in Community Support
Could some one explain how to use the linear pattern tool?
How do I choose a direction?
  • JinJin Member Posts: 8
    viru said:
    @ray_sleeper, Please refer below step for part and sketch linear pattern.
    1. Use Centered to make the seed instance/face/feature as the center of the pattern.
      In this case, the instance count is N instances from the seed (inclusive of the seed) in one direction and N instances from the seed (inclusive of the seed) in the other direction. With N being the number you enter in the Instance count field in the dialog:
    Hi,
    I have one question regarding the centered option. I am trying to make ventilation cuts in a plastic casing and I used the pattern tool on an extrude feature to create them. Then I used a mirror feature to copy those cuts to the other side of the casing. Now, I noticed that the center piece is not becoming part of the mirrored linear pattern - it is missing on the other side.
    What am I doing wrong?
    edited January 2018
    Wow, that first reply was a loooong copy/paste, @viru :p Next time just paste a link to the help file?
    @Jin, the pattern and the seed are different features. In the Mirror definition, make sure you select the seed feature, too.
    Also, everyone at Onshape will tell you that feature patterns/mirrors are much slower to rebuild than face/body patterns.
    Aah... that explains it, thank you!
    Hmm, OK, I will try that. I am a beginner, so for now I was just happy to get where I wanted just "somehow" ;)
Howdy, Stranger!
