questions on using onshape with a trotec laser
adeeb_shihadehadeeb_shihadeh Member Posts: 1
I just got a trotec laser, and I'm trying to find out the fastest way to go from an onshape part to a laser cut piece of material. Do I need to make a drawing? Do I need to export to dxf
    No, you do not need to make a drawing - simply RMB over any planar face and export directly to DXF/DWG.
    Philip Thomas - Onshape
  • scott_stapscott_stap Member Posts: 2
    Me too! Trying to export as DXF to provide to laser cutter.
